Introduction
This guide teaches the user how to replace the automatic circuit breaker in your Cuisinart DLC-8F. The removal of the automatic circuit breaker first requires the removal of the power cable and all of this can be done with just a Phillips #2 screwdriver. This is an easy process and should only take 15 minutes.
Ce dont vous avez besoin
Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
