Aller au contenu principal
Cuisinart Griddler GR- 4N Knobs Replacement
Ce dont vous avez besoin
  1. Cuisinart Griddler GR- 4N Knobs Replacement, Cooking Surfaces: étape 1, image 1 de 2 Cuisinart Griddler GR- 4N Knobs Replacement, Cooking Surfaces: étape 1, image 2 de 2
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR- 4N Knobs Replacement: étape 2, image 1 de 1
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR- 4N Knobs Replacement: étape 3, image 1 de 1
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR- 4N Knobs Replacement: étape 4, image 1 de 1
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR- 4N Knobs Replacement: étape 5, image 1 de 2 Cuisinart Griddler GR- 4N Knobs Replacement: étape 5, image 2 de 2
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
  6. Cuisinart Griddler GR- 4N Knobs Replacement, Cuisinart Griddler GR- 4N Disassembly: étape 6, image 1 de 1
    • Remove the two 6 mm Phillips #2 screws that secure the knob circuit board.
    • Move the circuit board to the side so it is out of the way.
  7. Cuisinart Griddler GR- 4N Knobs Replacement: étape 7, image 1 de 1
    • Remove the two 6 mm Phillips #2 screws that secure the white plastic LED holder.
  8. Cuisinart Griddler GR- 4N Knobs Replacement, Knobs: étape 8, image 1 de 1
    • Pinch back plastic arms on knob while pulling out the knob.
  9. Cuisinart Griddler GR- 4N Knobs Replacement: étape 9, image 1 de 1
    • Pop the new knob back into the hole and the repair is complete.
2 autres ont terminé cette réparation.
Kayla Londono
Membre depuis le 04/15/16
614 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 1-12, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 1-12, Maness Spring 2016
CPSU-MANESS-S16S1G12
4 membres
6 tutoriels rédigés
12 commentaires
Where do you find the replacement knobs?
Chris Reece - Réponse
im in same boat can't find the dials/knobs- 2 of mine are broken and useless
Mark Stevens - Réponse
Cuisinart offers NO help. I will have to toss out a $100.00 unit over a $2.00 part.
Nick - Réponse
I have several cuisinart appliances. I won't ever buy another. I need one replacement knob, the best they can do is 20 percent off on a new griddler . I can get that from bed bath and beyond. Thanks cuisinart, finding new brands. Cuisinart is dead to me.
allen brathwaite - Réponse
Same here 2 knobs broken in 2 years and no way to find a new one
benoitcerrina - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 30
30 derniers jours : 92
Total : 9,084
