Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
If the indication lights on the Cuisinart Griddler GR- 4N have stopped working when your device is in use then the this guide will help you replace the LED lights.
Pièces
Aucune pièce spécifiée.
  1. Ensure device is turned unplugged, cooled down and clean before attempting any replacements. Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  6. Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out. Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
  7. Remove the two 6 mm Phillips #2 screws that secure the knob circuit board.
    • Remove the two 6 mm Phillips #2 screws that secure the knob circuit board.
    • Move the circuit board to the side so it is out of the way.
  8. Remove the two 6 mm Phillips #2 screws that secure the white plastic LED holder.
    • Remove the two 6 mm Phillips #2 screws that secure the white plastic LED holder.
  9. Cut the zip ties which hold the LED lights in place with scissors/knife. Cut the zip ties which hold the LED lights in place with scissors/knife.
    • Cut the zip ties which hold the LED lights in place with scissors/knife.
  10. Slide back black plastic covers and cut the two wires connected to the LED with a pair of scissors. The LED bulb should now be free to remove. In order to replace bulb you must solder the new LED into the existing wires.
    • Slide back black plastic covers and cut the two wires connected to the LED with a pair of scissors.
    • The LED bulb should now be free to remove. In order to replace bulb you must solder the new LED into the existing wires.
    • Upon soldering the LED will need to be zip tied back in place.
Kayla Londono
Membre depuis le 15/04/2016
560 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 1-12, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 1-12, Maness Spring 2016
CPSU-MANESS-S16S1G12
4 membres
6 tutoriels rédigés
Hai
is there any body can come home and help me
or any place I can send my machine and repair
regds
Leela Manilal
Raghavan Manilal - Réponse
any tips on how to fix a broken thermostat?
Jean-Michel Léon - Réponse
Will any green LED work? Or does it have to be a particular voltage?
Bob Mounger - Réponse
How do I get the heating element off? It seems pretty securely connected via the red and white wires connected to the machine. Is there an easy way to disassemble this part? I honestly just want to clean the baked on grease on the pans but I’ve got to remove the heating element in order to do that. Any advice would be most appreciated. Thanks!
Katie Hoppmann - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 526
