Aller au contenu principal
Cuisinart Griddler GR-4N Cooking Surfaces Replacement
Ce dont vous avez besoin
  1. Cuisinart Griddler GR-4N Cooking Surfaces Replacement, Cooking Surfaces: étape 1, image 1 de 2 Cuisinart Griddler GR-4N Cooking Surfaces Replacement, Cooking Surfaces: étape 1, image 2 de 2
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: étape 2, image 1 de 1
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: étape 3, image 1 de 1
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: étape 4, image 1 de 1
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: étape 5, image 1 de 2 Cuisinart Griddler GR-4N Cooking Surfaces Replacement: étape 5, image 2 de 2
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
Kayla Londono
Membre depuis le 04/15/16
632 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 1-12, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 1-12, Maness Spring 2016
CPSU-MANESS-S16S1G12
4 membres
6 tutoriels rédigés
Un commentaire
The 'cooking plates' on my unit always fall off. I tried bending the tabs to make it tighter - did not help. Any ideas?
M S - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 32
Total : 4,031
