Aller au contenu principal
Cuisinart Smart Stick CSB-75 Electrical Cord Replacement
Ce dont vous avez besoin
  1. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement, Electrical Cord: étape 1, image 1 de 3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement, Electrical Cord: étape 1, image 2 de 3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement, Electrical Cord: étape 1, image 3 de 3
    • Located on the back of the motor body are three screw covers. To remove the three grey screw covers, use a Flat Head Screwdriver (1.0mm or 1.5mm).
    • After prying these off, the screws will be exposed.
  2. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: étape 2, image 1 de 2 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: étape 2, image 2 de 2
    • Remove three 13.3 mm Phillips PH#2 screws.
  3. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: étape 3, image 1 de 3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: étape 3, image 2 de 3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: étape 3, image 3 de 3
    • Pry open Cuisinart using a plastic opening tool.
    • The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Make sure to pry open near the clips of the smart stick for easy opening.
  4. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: étape 4, image 1 de 3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: étape 4, image 2 de 3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: étape 4, image 3 de 3
    • Unscrew the 4 screws on the inside.
    • Remove 2 13.3mm Phillips PH#2 screws.
    • Remove 2 17.5 mm Phillips PH#2 screws.
    • Unscrewing these screws will isolate the switch board.
  5. Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: étape 5, image 1 de 3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: étape 5, image 2 de 3 Cuisinart Smart Stick CSB-75 Electrical Cord Replacement: étape 5, image 3 de 3
    • Refer to these steps on Soldering to replace the electrical cord in the smart stick.
    • Be careful when soldering; it gets very hot.
Jordan Robinson
Membre depuis le 09/02/15
557 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 16-2, Wollert Fall 2015 Membre de l'équipe USF Tampa, Team 16-2, Wollert Fall 2015
USFT-WOLLERT-F15S16G2
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 24
Total : 1,486
