Aller au contenu principal
Cuisinart TOA-60FR Function Switch Replacement
Ce dont vous avez besoin
  1. Cuisinart TOA-60FR Function Switch Replacement, Outside removal: étape 1, image 1 de 1
    • Using a 25-hexagon head, unscrew these 7.31 mm three screws.
  2. Cuisinart TOA-60FR Function Switch Replacement: étape 2, image 1 de 2 Cuisinart TOA-60FR Function Switch Replacement: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver, remove all these 7.31 mm screws.
    • Pull off the back.
  3. Cuisinart TOA-60FR Function Switch Replacement: étape 3, image 1 de 3 Cuisinart TOA-60FR Function Switch Replacement: étape 3, image 2 de 3 Cuisinart TOA-60FR Function Switch Replacement: étape 3, image 3 de 3
    • Flip the oven upside down.
    • Pick the grey stoppers out with a sprudger.
    • Using a Phillips #1 screwdriver, remove these three 11 mm screws.
  4. Cuisinart TOA-60FR Function Switch Replacement: étape 4, image 1 de 2 Cuisinart TOA-60FR Function Switch Replacement: étape 4, image 2 de 2
    • Unscrew all of the 11.05 mm screws that connect the outer shell to the device.
  5. Cuisinart TOA-60FR Function Switch Replacement: étape 5, image 1 de 3 Cuisinart TOA-60FR Function Switch Replacement: étape 5, image 2 de 3 Cuisinart TOA-60FR Function Switch Replacement: étape 5, image 3 de 3
    • Pull the top piece off.
    • Push down before pulling up to release the tabs.
  6. Cuisinart TOA-60FR Function Switch Replacement, Function Switch: étape 6, image 1 de 3 Cuisinart TOA-60FR Function Switch Replacement, Function Switch: étape 6, image 2 de 3 Cuisinart TOA-60FR Function Switch Replacement, Function Switch: étape 6, image 3 de 3
    • Inside of the device locate the function switch and remove the indicated screws (4.97mm).
  7. Cuisinart TOA-60FR Function Switch Replacement: étape 7, image 1 de 1
    • Unclip all connections.
    • Rotate function knob to broil so plastic tab is visible. Use screwdriver to push tab down and pull knob out from front side.
    • Remove 2 screws revealed under the front knob
TRiels
Membre depuis le 09/08/23
118 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
Anyone have a source for a replacement switch?
Josh - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 56
30 derniers jours : 165
Total : 842
