Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Cuisinart TOA-60FR Function Switch Replacement
Ce dont vous avez besoin
    1. Cuisinart TOA-60FR Function Switch Replacement, Outside removal: étape 1, image 1 de 1
      • Using a 25-hexagon head screwdriver, unscrew these three 7.31 mm screws.
      Demander à FixBot
      Ajouter un commentaire
    2. Cuisinart TOA-60FR Function Switch Replacement: étape 2, image 1 de 2 Cuisinart TOA-60FR Function Switch Replacement: étape 2, image 2 de 2
      • Using a Phillips #1 screwdriver, remove all of these 7.31 mm screws.
      • Pull off the back panel.
      Demander à FixBot
    3. Cuisinart TOA-60FR Function Switch Replacement: étape 3, image 1 de 3 Cuisinart TOA-60FR Function Switch Replacement: étape 3, image 2 de 3 Cuisinart TOA-60FR Function Switch Replacement: étape 3, image 3 de 3
      • Flip the oven upside down.
      • Use a spudger to pull out the grey stoppers.
      • Use a Phillips #1 screwdriver to remove all three 11 mm screws.
      Demander à FixBot
    4. Cuisinart TOA-60FR Function Switch Replacement: étape 4, image 1 de 2 Cuisinart TOA-60FR Function Switch Replacement: étape 4, image 2 de 2
      • Unscrew all of the 11.05 mm screws that connect the outer shell to the interior device.
      Demander à FixBot
    5. Cuisinart TOA-60FR Function Switch Replacement: étape 5, image 1 de 3 Cuisinart TOA-60FR Function Switch Replacement: étape 5, image 2 de 3 Cuisinart TOA-60FR Function Switch Replacement: étape 5, image 3 de 3
      • Push down with a screw driver between the tabs, then pull up to release the tabs. Pull the top piece off.
      Demander à FixBot
    1. Cuisinart TOA-60FR Function Switch Replacement, Function Switch: étape 6, image 1 de 3 Cuisinart TOA-60FR Function Switch Replacement, Function Switch: étape 6, image 2 de 3 Cuisinart TOA-60FR Function Switch Replacement, Function Switch: étape 6, image 3 de 3
      • Inside of the device locate the function switch and remove the indicated screws (4.97mm).
      Demander à FixBot
    2. Cuisinart TOA-60FR Function Switch Replacement: étape 7, image 1 de 1
      • Unclip all connections.
      Demander à FixBot
    3. Cuisinart TOA-60FR Function Switch Replacement: étape 8, image 1 de 3 Cuisinart TOA-60FR Function Switch Replacement: étape 8, image 2 de 3 Cuisinart TOA-60FR Function Switch Replacement: étape 8, image 3 de 3
      • Rotate function knob to broil so plastic tab is visible when looking from the inside between the switch and control panel. Use screwdriver to push tab down and pull knob out from front side.
      • Remove 2 screws revealed under the front knob
      Demander à FixBot
7 autres ont terminé cette réparation.
TRiels
Membre depuis le 09/08/23
244 Réputation
1 tutoriel rédigé
Équipe
14 commentaires de tutoriel
Anyone have a source for a replacement switch?
Josh - Réponse Partager
I ordered mine on Amazon
Martin Baumeister - Réponse Partager
Big thanks for providing these instructions! It worked!
Thanks for the guide. Saved me the headache of having to find a new toaster oven and paying for it.
For those needing it, the part I ordered and used is part model number FZ31-9E (11 pins 7 positions) from amazon.
The switch will also have letters and numbers corresponding to the orientation as in step 6 so keep an eye out for that!
Adam Nguyen - Réponse Partager
Part of Step 8...Difficult to understand picture how to remove knob on switch? i did follow up instruction that i didn't clear instruction if you have any video how to remove knob from panel switch?
Thanks Todd
Todd Bouma - Réponse Partager
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 66
30 derniers jours : 215
Total : 7,241
