Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Cuisinart TOA-60FR Light Switch Spring Replacement
Ce dont vous avez besoin
    1. Cuisinart TOA-60FR Light Switch Spring Replacement, Outside removal: étape 1, image 1 de 1
      • Using a 25-hexagon head screwdriver, unscrew these three 7.31 mm screws.
      Demander à FixBot
      Ajouter un commentaire
    2. Cuisinart TOA-60FR Light Switch Spring Replacement: étape 2, image 1 de 2 Cuisinart TOA-60FR Light Switch Spring Replacement: étape 2, image 2 de 2
      • Using a Phillips #1 screwdriver, remove all of these 7.31 mm screws.
      • Pull off the back panel.
      Demander à FixBot
    3. Cuisinart TOA-60FR Light Switch Spring Replacement: étape 3, image 1 de 3 Cuisinart TOA-60FR Light Switch Spring Replacement: étape 3, image 2 de 3 Cuisinart TOA-60FR Light Switch Spring Replacement: étape 3, image 3 de 3
      • Flip the oven upside down.
      • Use a spudger to pull out the grey stoppers.
      • Use a Phillips #1 screwdriver to remove all three 11 mm screws.
      Demander à FixBot
    4. Cuisinart TOA-60FR Light Switch Spring Replacement: étape 4, image 1 de 2 Cuisinart TOA-60FR Light Switch Spring Replacement: étape 4, image 2 de 2
      • Unscrew all of the 11.05 mm screws that connect the outer shell to the interior device.
      Demander à FixBot
    5. Cuisinart TOA-60FR Light Switch Spring Replacement: étape 5, image 1 de 3 Cuisinart TOA-60FR Light Switch Spring Replacement: étape 5, image 2 de 3 Cuisinart TOA-60FR Light Switch Spring Replacement: étape 5, image 3 de 3
      • Push down with a screw driver between the tabs, then pull up to release the tabs. Pull the top piece off.
      Demander à FixBot
    1. Cuisinart TOA-60FR Light Switch Spring Replacement, Light Switch Spring: étape 6, image 1 de 2 Cuisinart TOA-60FR Light Switch Spring Replacement, Light Switch Spring: étape 6, image 2 de 2
      • Unscrew these two screws to detach the light switch from the panel.
      Demander à FixBot
    2. Cuisinart TOA-60FR Light Switch Spring Replacement: étape 7, image 1 de 2 Cuisinart TOA-60FR Light Switch Spring Replacement: étape 7, image 2 de 2
      • Pull the back piece of the switch off of the clicking piece.
      Demander à FixBot
    3. Cuisinart TOA-60FR Light Switch Spring Replacement: étape 8, image 1 de 2 Cuisinart TOA-60FR Light Switch Spring Replacement: étape 8, image 2 de 2
      • Use a metal spudger to pry open the clicking piece.
      Demander à FixBot
    4. Cuisinart TOA-60FR Light Switch Spring Replacement: étape 9, image 1 de 1
      • Remove the broken spring and replace it with the new one.
      Demander à FixBot
Myra Chirchirillo
Membre depuis le 09/08/23
121 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 22
Total : 613
