Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Cuisinart TOA-60FR Lightbulb Replacement
Ce dont vous avez besoin
    1. Cuisinart TOA-60FR Lightbulb Replacement, Outside removal: étape 1, image 1 de 1
      • Using a 25-hexagon head screwdriver, unscrew these three 7.31 mm screws.
      Demander à FixBot
      Ajouter un commentaire
    2. Cuisinart TOA-60FR Lightbulb Replacement: étape 2, image 1 de 2 Cuisinart TOA-60FR Lightbulb Replacement: étape 2, image 2 de 2
      • Using a Phillips #1 screwdriver, remove all of these 7.31 mm screws.
      • Pull off the back panel.
      Demander à FixBot
    3. Cuisinart TOA-60FR Lightbulb Replacement: étape 3, image 1 de 3 Cuisinart TOA-60FR Lightbulb Replacement: étape 3, image 2 de 3 Cuisinart TOA-60FR Lightbulb Replacement: étape 3, image 3 de 3
      • Flip the oven upside down.
      • Use a spudger to pull out the grey stoppers.
      • Use a Phillips #1 screwdriver to remove all three 11 mm screws.
      Demander à FixBot
    4. Cuisinart TOA-60FR Lightbulb Replacement: étape 4, image 1 de 2 Cuisinart TOA-60FR Lightbulb Replacement: étape 4, image 2 de 2
      • Unscrew all of the 11.05 mm screws that connect the outer shell to the interior device.
      Demander à FixBot
    5. Cuisinart TOA-60FR Lightbulb Replacement: étape 5, image 1 de 3 Cuisinart TOA-60FR Lightbulb Replacement: étape 5, image 2 de 3 Cuisinart TOA-60FR Lightbulb Replacement: étape 5, image 3 de 3
      • Push down with a screw driver between the tabs, then pull up to release the tabs. Pull the top piece off.
      Demander à FixBot
    1. Cuisinart TOA-60FR Lightbulb Replacement, Lightbulb: étape 6, image 1 de 2 Cuisinart TOA-60FR Lightbulb Replacement, Lightbulb: étape 6, image 2 de 2
      • Remove these two 12.8 mm screws at the top on each side.
      • Remove two 12.8 mm screws at the bottom, as demonstrated in the first picture.
      • You should now be able to push the back out with the four screws removed to see the light bulb.
      Demander à FixBot
    2. Cuisinart TOA-60FR Lightbulb Replacement: étape 7, image 1 de 1
      • Remove these four screws.
      • Pull the light away from it's window.
      Demander à FixBot
    3. Cuisinart TOA-60FR Lightbulb Replacement: étape 8, image 1 de 2 Cuisinart TOA-60FR Lightbulb Replacement: étape 8, image 2 de 2
      • Using a wrench, remove the washer.
      • Pull the silver casing off the lightbulb.
      Demander à FixBot
    4. Cuisinart TOA-60FR Lightbulb Replacement: étape 9, image 1 de 2 Cuisinart TOA-60FR Lightbulb Replacement: étape 9, image 2 de 2
      • Now unscrew the lightbulb to replace it with a new one.
      Demander à FixBot
Anastasia Hopkins
Membre depuis le 09/08/23
395 Réputation
2 tutoriels rédigés
Équipe
1 commentaire de tutoriel
You don't tell the information about the bulb! I'd like to buy one before I tear this oven apart.
Gary Richard Coulter - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 57
Total : 1,585
