Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Cuisinart TOA-60FR Thermal Fuse Replacement
Ce dont vous avez besoin
    1. Cuisinart TOA-60FR Thermal Fuse Replacement, Outside removal: étape 1, image 1 de 1
      • Using a 25-hexagon head screwdriver, unscrew these three 7.31 mm screws.
      Demander à FixBot
      Ajouter un commentaire
    2. Cuisinart TOA-60FR Thermal Fuse Replacement: étape 2, image 1 de 2 Cuisinart TOA-60FR Thermal Fuse Replacement: étape 2, image 2 de 2
      • Using a Phillips #1 screwdriver, remove all of these 7.31 mm screws.
      • Pull off the back panel.
      Demander à FixBot
    3. Cuisinart TOA-60FR Thermal Fuse Replacement: étape 3, image 1 de 3 Cuisinart TOA-60FR Thermal Fuse Replacement: étape 3, image 2 de 3 Cuisinart TOA-60FR Thermal Fuse Replacement: étape 3, image 3 de 3
      • Flip the oven upside down.
      • Use a spudger to pull out the grey stoppers.
      • Use a Phillips #1 screwdriver to remove all three 11 mm screws.
      Demander à FixBot
    4. Cuisinart TOA-60FR Thermal Fuse Replacement: étape 4, image 1 de 2 Cuisinart TOA-60FR Thermal Fuse Replacement: étape 4, image 2 de 2
      • Unscrew all of the 11.05 mm screws that connect the outer shell to the interior device.
      Demander à FixBot
    5. Cuisinart TOA-60FR Thermal Fuse Replacement: étape 5, image 1 de 3 Cuisinart TOA-60FR Thermal Fuse Replacement: étape 5, image 2 de 3 Cuisinart TOA-60FR Thermal Fuse Replacement: étape 5, image 3 de 3
      • Push down with a screw driver between the tabs, then pull up to release the tabs. Pull the top piece off.
      Demander à FixBot
    1. Cuisinart TOA-60FR Thermal Fuse Replacement, Locate the Thermal Fuse: étape 6, image 1 de 1
      • The thermal fuse will be in a white silicone sleeve, held by it's own bracket
      Demander à FixBot
    2. Cuisinart TOA-60FR Thermal Fuse Replacement, Expose the fuse: étape 7, image 1 de 2 Cuisinart TOA-60FR Thermal Fuse Replacement, Expose the fuse: étape 7, image 2 de 2
      • slide the sleeve and the thermal fuse out of the bracket, and pull the sleeve down the cable, exposing the fuse
      Demander à FixBot
    3. Cuisinart TOA-60FR Thermal Fuse Replacement, Remove the broken fuse: étape 8, image 1 de 2 Cuisinart TOA-60FR Thermal Fuse Replacement, Remove the broken fuse: étape 8, image 2 de 2
      • To remove the original fuse, clip the fuse leads close to the body of the device.
      • The leads of the old fuse will serve as a connection point for the new fuse
      Demander à FixBot
    4. Cuisinart TOA-60FR Thermal Fuse Replacement, Install the new fuse: étape 9, image 1 de 3 Cuisinart TOA-60FR Thermal Fuse Replacement, Install the new fuse: étape 9, image 2 de 3 Cuisinart TOA-60FR Thermal Fuse Replacement, Install the new fuse: étape 9, image 3 de 3
      • Install the new fuse by twisting the leads of the new fuse tightly with the old leads.
      • this is easiest with a pair of needle nose pliers
      • NOTE: the electrical connection must be secure, so try and get at least 3 twists between the two, and ensure that they are twisting TOGETHER (like a candy cane), and not one around the other
      • Bend the connections so they don't stick out, and are in line with the cable, and ensure that no shorts are occurring across the fuse.
      Demander à FixBot
    5. Cuisinart TOA-60FR Thermal Fuse Replacement, Re-install the fuse sleeve: étape 10, image 1 de 2 Cuisinart TOA-60FR Thermal Fuse Replacement, Re-install the fuse sleeve: étape 10, image 2 de 2
      • Slide the silicone sleeve back over the fuse, and push it back into the bracket
      • NOTE: try and ensure that the bracket is around the body of the fuse, so it is securely held in it's original location
      Demander à FixBot
To reassemble your device, follow these instructions (Starting with step 5) in reverse order.
emtotheipi
Membre depuis le 05/31/26
133 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 41
30 derniers jours : 160
Total : 301
