Introduction
To remove the disc tray bracket, you must first remove the top panel of the DVD, which exposes the disc tray bracket. The Disc tray bracket sits on top of the disc tray to keep the disc in place while in use.
Pièces
Aucune pièce nécessaire.
Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
  • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
  • Unplug the DVD player from the wall socket.
  • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
Ajouter un commentaire
Remove the top panel of the DVD Player by:
  • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
  • Remove the 6.3mm screws keeping the disc tray bracket connected to the disc tray.
  • Lift up on the bracket by:
    • Sliding the disc tray bracket forward.
    • Lifting the back edge up.
2 autre(s) ont terminé cette réparation.
Chris Menezes
Membre depuis le 07/04/2014
626 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 6-5, Forte Spring 2014 Membre de l'équipe Cal Poly, Team 6-5, Forte Spring 2014
CPSU-FORTE-S14S6G5
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 55
Total : 2,032
