Aller au contenu principal
Introduction
The membrane keys on the keyboard may become stuck or cease functioning due to wear or improper maintenance. This guide will show how to replace keys that have stopped functioning.
Pièces
Aucune pièce spécifiée.
  1. Be sure to unplug the keyboard before starting the disassembly. Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. Remove the sixteen 5 mm length screws using the Phillips head #2. One of the screws may be located underneath a manufacturer's sticker.
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  3. Lift up and remove the plastic casing.
    • Lift up and remove the plastic casing.
  4. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  5. Remove the metal backing located directly underneath the white plastic casing.
    • Remove the metal backing located directly underneath the white plastic casing.
  6. Be careful not to pull too hard on the ribbon cable, as it may break.
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
  7. Carefully remove the LED board, which should now come free from the casing.
    • Carefully remove the LED board, which should now come free from the casing.
  8. Now the cell membrane should be exposed, gently lift this part and ensure that the rubber buffers are all intact to the membrane, if not pick up the buffers and set to the side.
    • Now the cell membrane should be exposed, gently lift this part and ensure that the rubber buffers are all intact to the membrane, if not pick up the buffers and set to the side.
  9. The keyboard should now be free to move, pick up the entire keyboard membrane and search for the key that needs to be replaced, to assist in remembering which key needs to be replaced place a small marker dot on the individual key back.
    • The keyboard should now be free to move, pick up the entire keyboard membrane and search for the key that needs to be replaced, to assist in remembering which key needs to be replaced place a small marker dot on the individual key back.
Katherine Von Braunsberg
Membre depuis le 12/02/2018
341 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S15-G2, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
4 membres
5 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 11
Total : 232
