Introduction
Ce demontage vous montra comment accéder à l'intérieur de votre Xbox 360 S pour les réparations que vous devez faire.
Ce dont vous avez besoin
Glissez le levier en le tirant vers le haut, pour enlever cette partie du cache en plastique.
Des l'autre côté, prenez votre tournevis plat et défaites le loquet. Il y a un loquet plus dur plus profondément à l'intérieur, donc du coup vous devez enfoncer plus le tournevis et tâtonner pour le trouver. Il peut être utile de tirer les deux côtés de votre autocollant de sécurité Xbox.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
13 commentaires
Some of these photos are just zoomed in and I have no idea which side, or which way up they are in respect of the console. I recommend further photos for clarity.
I don’t have this console, but I just like going through the teardowns.
i have the console and it was pretty easy to follow, the only thing was the last clip he was saying to just feel around for, i just pushed in on the spot where it would be and it separated easily after that
This is pretty bad, pretty vague. I had to refer to a YouTube video for more information and a visual demonstration because this how-to is sparse in information. This article fails to mention what is happening at crucial steps and does not describe how it should feel when pieces come apart; if I only had this article to refer to, I probably would have given up in fear that I’d damage the case or system. I did eventually get my case apart, hardly any help from this source, sadly.
Hi Anthony,
As stated in the warning at top, a teardown is an educational look at the device, and is not meant to be used as a guide. Our repair guides will show up here, and contain accurate details (such as tools needed, how to unlock ZIF connectors, etc.) as well as step by step instructions on how to complete the repair.
In the middle of the sticker on the back there is a pin hole to put something into to get the last clip off
