Introduction
Assurez-vous que votre Zeppelin est configuré et fonctionne via AirPlay. Après avoir retiré le bras de la station d'accueil, votre Zeppelin n'aura plus de voyant d'état.
Le retrait du bras de la station d'accueil peut annuler votre garantie.
Ce dont vous avez besoin
Placez le Zeppelin à l'envers. Pour ce faire, vous pouvez utiliser les pièces d'emballage fournies.
18 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
30 commentaires de tutoriel
Caution Loud volume is distorted. I tried this with hard plastic and when bass notes were at 1/2 or louder volume there was a loud rattling sound. Tried again with a cut up black sock taped and cut in place, still distorted but barely at normal volumes. Good thing nothing is permanent as going back it sounds fine. Test a song with punchy bass loud before and after, I used Too Late by Ariane Moffatt and Counting by Autre Ne Veut. I wouldn't have noticed with the black fabric if I wouldn't have been listening for it. Probably not meant to be a semi-open speaker. B&W could have saved me some time and stated the reason why, not just the 'void warranty' I read everywhere that has ended anyway.
Any one have a docking arm assem. they want to sell. I'll pay good money for a working one. Mine got damaged. i12gocruzin2@yahoo.com Tim
As an appendix to this, you can also pull the dock arm apart, remove the wires, remove the dock connector and retain the led wire, put the LED wire inside the base, cut the dock arm at the base and then screw it back together. Fill in the cable holes with hot glue, and then reattach the base and you get a dock-less zeppelin with a glowing hole in the base with the ability to blast it at full volume with no distortion!
15 mins with a screwdriver and a hot glue gun and a hobby saw.
