Introduction
There are times that the antenna of the Wi-Fi Baby Camera does not work. This is a step by step guide on how to remove a faulty antenna from the Wi-Fi Baby Camera and replacing it with a working antenna.
Ce dont vous avez besoin
Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
Outil utilisé dans cette étape :Tweezers$4.99
There will be a light yellow rubber stopper that is holding the antenna in place.
With your tweezers, gently tug on the stopper to make it come out, or at least come loose.
If the stopper does not completely come out, use the round top of the antenna to push down on it.
