Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
There are times that the antenna of the Wi-Fi Baby Camera does not work. This is a step by step guide on how to remove a faulty antenna from the Wi-Fi Baby Camera and replacing it with a working antenna.
  1. Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
    • Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
  2. Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
    • Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
  3. Replace your accent ring with whichever color you choose.
    • Replace your accent ring with whichever color you choose.
  4. Remove one Phillips #2 screw from each side of the camera lens. Remove one Phillips #2 screw from each side of the camera lens.
    • Remove one Phillips #2 screw from each side of the camera lens.
  5. OUVRIR TOUS LES ONGLETS
    Kits de mise à jour de RAM pour Mac
    Voir les kits
    Assez de RAM
    pour ouvrir tous les onglets
    Voir les kits
  6. Pull the Wi-Fi Baby Camera open. It should be easily done after the screws are removed. It should be easily done after the screws are removed.
    • Pull the Wi-Fi Baby Camera open.
    • It should be easily done after the screws are removed.
  7. Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire. Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
    • Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
  8. Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in. Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in. Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
    • Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
  9. Once you have the back casing removed from the other half of the device, it should look like this with the antenna poking out.
    • Once you have the back casing removed from the other half of the device, it should look like this with the antenna poking out.
  10. There will be a light yellow rubber stopper that is holding the antenna in place. With your tweezers, gently tug on the stopper to make it come out, or at least come loose. If the stopper does not completely come out, use the round top of the antenna to push down on it.
    • There will be a light yellow rubber stopper that is holding the antenna in place.
    • With your tweezers, gently tug on the stopper to make it come out, or at least come loose.
    • If the stopper does not completely come out, use the round top of the antenna to push down on it.
    • You can do this simply by pulling the antenna as close to the back casing as possible, and then pushing down on it until the rubber stopper comes out completely.
    • After it has come out, it can either be taken off from the antenna and set aside, or it can be kept on.
  11. Once the rubber stopper has been pushed out, you will now be able to easily pull the antenna out from the back casing. After it has been removed, you are  now able to replace the antenna of your Wi-Fi Baby Camera.
    • Once the rubber stopper has been pushed out, you will now be able to easily pull the antenna out from the back casing.
    • After it has been removed, you are now able to replace the antenna of your Wi-Fi Baby Camera.
Alexis Clopton
Membre depuis le 09/10/2018
97 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S1-G5, Leahy Fall 2018 Membre de l'équipe USF Tampa, Team S1-G5, Leahy Fall 2018
USFT-LEAHY-F18S1G5
4 membres
4 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 158
