Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre D-Link DNS-323, utilisez notre manuel de réparation.
  1. D-Link DNS-323 Teardown, D-Link DNS-323 Teardown: étape 1, image 1 de 3 D-Link DNS-323 Teardown, D-Link DNS-323 Teardown: étape 1, image 2 de 3 D-Link DNS-323 Teardown, D-Link DNS-323 Teardown: étape 1, image 3 de 3
    • The DNS-323 is a powerful NAS with Gigabit Ethernet, print server and extension via software. It can have a FTP server, DHCP, and even Bittorrent!
    • This is my first disassembling, please be patient, correct my grammar mistakes if you find some.
    • This was pretty easy, nothing compared to iPods or Macs.
  2. D-Link DNS-323 Teardown: étape 2, image 1 de 2 D-Link DNS-323 Teardown: étape 2, image 2 de 2
    • First thing first remove the frontal part by sliding it up and pulling out.
    • You will be able to see the hard disks.
    • By the way, the DNS-323 can support up to 3TB of disk space with the new firmware update. That's 1.5TB per disk! Could you imagine such capacity twenty years ago?
  3. D-Link DNS-323 Teardown: étape 3, image 1 de 3 D-Link DNS-323 Teardown: étape 3, image 2 de 3 D-Link DNS-323 Teardown: étape 3, image 3 de 3
    • Now it's time to remove the Hard Disks.
    • BE CAREFUL, when handling these parts do not touch the circuits, do not shock, and do not let your dog play with them. I'm serious, this could lead into data loss.
    • At the back of the DNS, pull out the two little levers to make the hard drives come out.
    • Gently put them in a safe place until the whole unit is reassembled.
    • The drives are order-specific! Remember if they were right or left, otherwise you will be prompted with a message when accessing the NAS after reassembly.
  4. D-Link DNS-323 Teardown: étape 4, image 1 de 2 D-Link DNS-323 Teardown: étape 4, image 2 de 2
    • Remove the frontal part.
    • There are two screws; remove them with a cross screwdriver.
    • Pull off the little sheet of metal that's covering the front.
  5. D-Link DNS-323 Teardown: étape 5, image 1 de 3 D-Link DNS-323 Teardown: étape 5, image 2 de 3 D-Link DNS-323 Teardown: étape 5, image 3 de 3
    • Now it's time to open the rear.
    • Locate the four rubber caps which cover the screws, then remove them with a flat screwdriver.
    • Remove the screws with a Phillips screwdriver.
  6. D-Link DNS-323 Teardown: étape 6, image 1 de 3 D-Link DNS-323 Teardown: étape 6, image 2 de 3 D-Link DNS-323 Teardown: étape 6, image 3 de 3
    • Take off the rear and unscrew the next four screw showed in the picture.
    • These screws are hard! Pay attention not to strip them!
  7. D-Link DNS-323 Teardown: étape 7, image 1 de 3 D-Link DNS-323 Teardown: étape 7, image 2 de 3 D-Link DNS-323 Teardown: étape 7, image 3 de 3
    • Pull the board to make it slide out of the case.
    • The board is quite simple, a little ARM-based computer mounting Linux. (is it?). The condensers are mostly for power supply, doubled because of the two HDDs.
    • Remove two more screws under the circuit.
  8. D-Link DNS-323 Teardown: étape 8, image 1 de 3 D-Link DNS-323 Teardown: étape 8, image 2 de 3 D-Link DNS-323 Teardown: étape 8, image 3 de 3
    • Time to remove the iron part.
    • Pull out the fan wire. If you need you can use a flat screwdriver, paying attention not to break it.
    • It's time to detach the SATA adapters with the fan, so you can contemplate the main circuit.
    • Don't remove the battery as this could lead to time loss, some basic (board-level) settings, and unwanted resets.
  9. D-Link DNS-323 Teardown: étape 9, image 1 de 3 D-Link DNS-323 Teardown: étape 9, image 2 de 3 D-Link DNS-323 Teardown: étape 9, image 3 de 3
    • Now all about the chips
    • The first chip looks like a flash memory for the ROM, or the random memory for the OS, there are two of them; Labelled 921EA C HY5DU56 1622FTP-043 Made in Korea NWFM136SAG3
    • Marvell 88F8152-A2 "Feroceon(r)" Storage Networking SoC (System-on-Chip)
    • A 12 to 24 bit multiplexed D-type latch marked 94CJNQK ALVCH162260 , see more there -->
    • http://focus.ti.com/docs/prod/folders/pr...
    • Eon SiliconSolution Inc EN29LV640B-90TIP 64Mbit Flash memory
  10. D-Link DNS-323 Teardown: étape 10, image 1 de 2 D-Link DNS-323 Teardown: étape 10, image 2 de 2
    • Last chip... Marvell Alaska 88E1111 single-port GbE transceiver. Markings: 88E1111-BAB1 6MAE490301.4 0914 B2P Taiwan
    • Remove the last screws.
    • That's not useful unless you want to replace the fan; six screws keep the two SATA connectors and...
    • ...four tapping screws hold the fan.
  11. D-Link DNS-323 Teardown: étape 11, image 1 de 2 D-Link DNS-323 Teardown: étape 11, image 2 de 2
    • That'all folks! The DNS-323 is now disassembled. If you want to put things back just follow this guide backwards!
    • Guide made by Mc128k.
Mc128k
Membre depuis le 02/16/10
243 Réputation
2 tutoriels rédigés
8 commentaires
Awesome teardown G!
Miroslav Djuric - Réponse
Thank you so much! It's only my first guide, but I'm going to post fun stuff lately!
Please always watch for grammar mistakes!
Mc128k - Réponse
Very nice teardown. The pictures were very clear unlike my iPhone dock tear down. I'm making another teardown today. Keep up the good work Mc128k! :)
Nicholas Ouimet - Réponse
Yes, that's PER disk, thank you.
Mc128k - Réponse
I'm having to buy a replacement power supply for my DNS-323. Do you know the pinout set up for it?
Dave - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 16
30 derniers jours : 46
Total : 38,844
