Aller au contenu principal
DBPOWER T20 Speaker Replacement
Ce dont vous avez besoin
  1. DBPOWER T20 Speaker Replacement, DBPOWER T20 Disassembly: étape 1, image 1 de 1
    • Flip the device and lay flat.
  2. DBPOWER T20 Speaker Replacement: étape 2, image 1 de 1
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Speaker Replacement: étape 3, image 1 de 3 DBPOWER T20 Speaker Replacement: étape 3, image 2 de 3 DBPOWER T20 Speaker Replacement: étape 3, image 3 de 3
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Speaker Replacement: étape 4, image 1 de 1
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Speaker Replacement: étape 5, image 1 de 2 DBPOWER T20 Speaker Replacement: étape 5, image 2 de 2
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Speaker Replacement: étape 6, image 1 de 3 DBPOWER T20 Speaker Replacement: étape 6, image 2 de 3 DBPOWER T20 Speaker Replacement: étape 6, image 3 de 3
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Speaker Replacement: étape 7, image 1 de 2 DBPOWER T20 Speaker Replacement: étape 7, image 2 de 2
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Speaker Replacement: étape 8, image 1 de 1
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Speaker Replacement: étape 9, image 1 de 2 DBPOWER T20 Speaker Replacement: étape 9, image 2 de 2
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Speaker Replacement: étape 10, image 1 de 2 DBPOWER T20 Speaker Replacement: étape 10, image 2 de 2
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Speaker Replacement, Speaker: étape 11, image 1 de 2 DBPOWER T20 Speaker Replacement, Speaker: étape 11, image 2 de 2
    • Remove the two (3 mm) screws connecting the bracket down and pull out the reflector, using a J0 Philips Head Screwdriver.
  12. DBPOWER T20 Speaker Replacement: étape 12, image 1 de 3 DBPOWER T20 Speaker Replacement: étape 12, image 2 de 3 DBPOWER T20 Speaker Replacement: étape 12, image 3 de 3
    • Slide the mirror straight up to remove.
  13. DBPOWER T20 Speaker Replacement: étape 13, image 1 de 3 DBPOWER T20 Speaker Replacement: étape 13, image 2 de 3 DBPOWER T20 Speaker Replacement: étape 13, image 3 de 3
    • Slide out the power source and disconnect its cables from the power jack and the light.
  14. DBPOWER T20 Speaker Replacement: étape 14, image 1 de 3 DBPOWER T20 Speaker Replacement: étape 14, image 2 de 3 DBPOWER T20 Speaker Replacement: étape 14, image 3 de 3
    • Remove the screws holding down the first speaker with a J0 screwdriver.
    • Remove the screws holding down the second speaker down.
2 autres ont terminé cette réparation.
Ryan Goldin
Membre depuis le 02/15/18
245 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S16-G2, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 12
Total : 434
