Aller au contenu principal
DCC-3200 Faulty Power Cord Replacement
Ce dont vous avez besoin
  1. DCC-3200 Faulty Power Cord Replacement, Faulty Power Cord: étape 1, image 1 de 1
    • First, please be sure that the device is unplugged and that there is no water in the reservoir.
    • Check the power cord for frays or cracks.
  2. DCC-3200 Faulty Power Cord Replacement: étape 2, image 1 de 1
    • If the cord appears fine, please flip the device upside-down and unscrew the 4 screws on the bottom.
  3. DCC-3200 Faulty Power Cord Replacement: étape 3, image 1 de 1
    • Remove the bottom panel and unclip the power cord from the panel.
  4. DCC-3200 Faulty Power Cord Replacement: étape 4, image 1 de 1
    • With the front facing towards you upside down, to the top left of the circular hotplate is a beige circuit board with two screws on either side holding it in. Please unscrew them.
  5. DCC-3200 Faulty Power Cord Replacement: étape 5, image 1 de 1
    • Carefully remove the circuit board and unplug the gray ribbon wire that is plugged into it.
  6. DCC-3200 Faulty Power Cord Replacement: étape 6, image 1 de 1
    • Check to see if the power cord is connected properly to the circuit board.
  7. DCC-3200 Faulty Power Cord Replacement: étape 7, image 1 de 1
    • Strip the wire and twist with the other or solder it back on.
Hamad Khan
Membre depuis le 03/04/16
385 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 8-3, Botvin Spring 2016 Membre de l'équipe UMass Dartmouth, Team 8-3, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G3
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 75
Total : 2,242
