Aller au contenu principal
Pour réparer ensemble - Je crée un compte
DJI Mavic Pro Front Arm Assembly Replacement
Ce dont vous avez besoin
    1. DJI Mavic Pro Front Arm Assembly Replacement, Top Cover: étape 1, image 1 de 1
      • Remove 6 hex screws from top cover. These are 1.5 mm and the same length.
      Demander à FixBot
      Ajouter un commentaire
    2. DJI Mavic Pro Front Arm Assembly Replacement: étape 2, image 1 de 1
      • Remove two hex screws on either side of the gimbal. These are 1.5 mm and the same length as the 6 top cover screws.
      • Remove two smaller hex screws from the covers under the front arms. These are 1.5 mm and SHORTER than the prior screws.
      Demander à FixBot
    3. DJI Mavic Pro Front Arm Assembly Replacement: étape 3, image 1 de 1
      • Use the flat end of a spudger to remove the covers under the front arms
      • These covers are fitted tightly enough that it's difficult to get a pry tool underneath. I found that when I pressed my thumb against the outside corner (red arrow) I got just enough of a gap on the opposite side (orange arrow) to squeeze a pry tool into it.
      Demander à FixBot
    4. DJI Mavic Pro Front Arm Assembly Replacement: étape 4, image 1 de 2 DJI Mavic Pro Front Arm Assembly Replacement: étape 4, image 2 de 2
      • Remove the two 1.5mm hex screws under the cover
      Demander à FixBot
    5. DJI Mavic Pro Front Arm Assembly Replacement: étape 5, image 1 de 2 DJI Mavic Pro Front Arm Assembly Replacement: étape 5, image 2 de 2
      • Lift the back end of the cover
      • The cover is connected to the body by a cable. Don't open the cover all the way until this cable is unplugged!
      • Unplug the 6-pin GPS connector, then pry along the edges to release the plastic clips holding the top down
      • Remove the cover
      • The clips at the nose of the drone require some extra pressure to release
      Demander à FixBot
    6. DJI Mavic Pro Front Arm Assembly Replacement, Desolder the arm wires: étape 6, image 1 de 1
      • Desolder the larger gray motor wire running to the arm to be replaced
      • Desolder the larger white motor wire
      • Desolder the larger black motor wire
      • Desolder the smaller black LED wire
      • Desolder the smaller white LED wire
      • The marked wires are for the right arm. The wires to desolder when replacing the left arm are the mirror image of the ones shown here.
      • Don't forget that plastic has a tendency to melt when exposed to heat! I may or may not have disregarded this fact and put a mark on my drone...
      Demander à FixBot
    7. DJI Mavic Pro Front Arm Assembly Replacement, Remove the bottom heat plate: étape 7, image 1 de 1
      • Remove 2 hex screws with longer posts
      Demander à FixBot
    8. DJI Mavic Pro Front Arm Assembly Replacement: étape 8, image 1 de 1
      • Remove bottom heat plate
      • This plate may stick a bit due to the thermal compound underneath it. It's a good idea to replace the thermal paste during reassembly
      Demander à FixBot
    9. DJI Mavic Pro Front Arm Assembly Replacement, Antenna cable: étape 9, image 1 de 1
      • If replacing the right front leg, unplug the white front antenna cable
      • If replacing the left front leg, unplug the black front antenna cable
      Demander à FixBot
    10. DJI Mavic Pro Front Arm Assembly Replacement, Remove front leg: étape 10, image 1 de 1
      • On the top of the drone, gently release the rear leg cable bundle from its cable management clip
      • Lift the white or black wire from the previous step up through the drone
      Demander à FixBot
    11. DJI Mavic Pro Front Arm Assembly Replacement: étape 11, image 1 de 1
      • Remove the Phillips head screw below the arm to be replaced
      Demander à FixBot
    12. DJI Mavic Pro Front Arm Assembly Replacement: étape 12, image 1 de 2 DJI Mavic Pro Front Arm Assembly Replacement: étape 12, image 2 de 2
      • Use a metal pry tool or flat head screwdriver to lift out the spring-loaded hinge
      • The spring in this hinge makes it difficult to reseat during reassembly. The easiest way I found to replace it was to fold the arm back into the closed position, and then grab across the top of the hinge with the very tip of a pair of needle nose pliers, using the pliers to rotate the hinge into position and press it down into place.
      Demander à FixBot
    13. DJI Mavic Pro Front Arm Assembly Replacement: étape 13, image 1 de 1
      • Remove the arm
      Demander à FixBot
7 autres ont terminé cette réparation.
Jamie Bell
Membre depuis le 08/01/19
433 Réputation
1 tutoriel rédigé
4 commentaires de tutoriel
Bravo, thanks for the guide! I found myself in the middle of my repair cursing that antenna wire as I didn’t want to pull up the main board. Then I remembered my trusty secret weapon “ifixit.com”. Oh did you save the day for sure, I was hoping for another access point to unclip the antenna, just had no idea where that would be. I’ve been a fixer for 20 + years, but DJI drones are not something you generally just want to go poking and prodding around blind. So a big thanks for helping me get in and out with ninja precision fellow fixer!
Caleb Fitzgerald - Réponse Partager
Glad I could help! They’re definitely complicated little buggers.
Jamie Bell - Réponse Partager
Did you use some glue along the three wires for the motor arm? This was destroyed when I replaced one damaged arm. Do you know what type of glue would be good to use?
jookieapc - Réponse Partager
I didn’t use any glue, and I haven’t had any issues with it leaving it out. It looks like the original glue is some sort of silicone glue. I would think you could probably use an electronics-safe silicone adhesive, like something you could get from a hobby shop, but I haven’t tried it myself so I couldn’t say for sure.
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 27
30 derniers jours : 107
Total : 6,140
