Introduction
This set of instructions will guide you through the replacements of the DJI Mavic Pro Upper Shell. You will need to remove the battery first in order to remove the upper shell. Before you begin, you should be aware that the plastic can end up slightly damaged when removing the shell.
Ce dont vous avez besoin
Grab both sides of the battery.
Pinch the releasing buttons on both sides of the battery.
Lift the battery up and out.
Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
6 autres ont terminé cette réparation.
2 commentaires
Well done, good instructions - are the two screws under the tabs shorter than the others from the shell?
Awesome descriptions were perfect except for saying there is 4 acres to be removed under the tabs behind the gimbal. Theirs only 2
