Aller au contenu principal
DJI Phantom 3 Advanced Landing Gear Replacement
Ce dont vous avez besoin
  1. DJI Phantom 3 Advanced Landing Gear Replacement, Battery: étape 1, image 1 de 2 DJI Phantom 3 Advanced Landing Gear Replacement, Battery: étape 1, image 2 de 2
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Landing Gear Replacement: étape 2, image 1 de 2 DJI Phantom 3 Advanced Landing Gear Replacement: étape 2, image 2 de 2
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: étape 3, image 1 de 3 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: étape 3, image 2 de 3 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: étape 3, image 3 de 3
    • Turn the phantom upside down.
    • Remove the eight 7.5mm long 3mm screws, securing the landing gear to the body of the quadcopter, with a T-8 screwdriver.
  4. DJI Phantom 3 Advanced Landing Gear Replacement: étape 4, image 1 de 3 DJI Phantom 3 Advanced Landing Gear Replacement: étape 4, image 2 de 3 DJI Phantom 3 Advanced Landing Gear Replacement: étape 4, image 3 de 3
    • Remove the rubber spacer in the landing gear by pushing the spacer out of the slot with your finger.
  5. DJI Phantom 3 Advanced Landing Gear Replacement: étape 5, image 1 de 3 DJI Phantom 3 Advanced Landing Gear Replacement: étape 5, image 2 de 3 DJI Phantom 3 Advanced Landing Gear Replacement: étape 5, image 3 de 3
    • Using a plastic opening tool, carefully separate the two pieces of plastic of the landing gear.
    • Be careful not to break the wire attached, as this is your receiver antenna.
  6. DJI Phantom 3 Advanced Landing Gear Replacement: étape 6, image 1 de 3 DJI Phantom 3 Advanced Landing Gear Replacement: étape 6, image 2 de 3 DJI Phantom 3 Advanced Landing Gear Replacement: étape 6, image 3 de 3
    • Feed the wire and attached plastic through the hole in the landing gear.
7 autres ont terminé cette réparation.
Quinn Tirpak
Membre depuis le 10/06/16
319 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 10-2, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 10-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G2
3 membres
12 tutoriels rédigés
Un commentaire
I have a single coax cable in my landing gear. the gear broke and the wire tore off the connector. How do I fix this?
Art - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 21
Total : 3,848
