Introduction
If the motors are intact but not starting, then there is a problem with the electronic speed controller. Use this guide to replace your damaged electronic speed controller.
Ce dont vous avez besoin
Use your finger tips to pinch the damaged propeller.
Twist the propeller counterclockwise and pull up to remove.
Remove the eight 7 mm hex screws by turning counterclockwise with a 2 mm hex bit.
Remove the two 4 mm screws using the JIS #000 bit.
Flip the metal bracket to the right and slide up.
Desolder the motor and LED wires on both sides of the board. For general soldering information, visit this Soldering Technique Guide.
2 autres ont terminé cette réparation.
