Introduction
If you have a damaged or malfunctioning motor, this guide will lead you step by step on how to replace those motors. For this guide you will need a soldering iron.
Ce dont vous avez besoin
Use your finger tips to pinch the damaged propeller.
Twist the propeller counterclockwise and pull up to remove.
Remove the eight 7 mm hex screws by turning counterclockwise with a 2 mm hex bit.
Remove the two 4 mm screws using the JIS #000 bit.
Flip the metal bracket to the right and slide up.
Desolder the motor and LED wires on both sides of the board. For general soldering information, visit this Soldering Technique Guide.
Pry the motor away from the arm.
Pull the motor and the motor wires out of the body.
2 autres ont terminé cette réparation.
