Aller au contenu principal
DJI Phantom 4 Advanced Remote Controller Back Panel Replacement
Ce dont vous avez besoin
  1. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: étape 2, image 1 de 2 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: étape 2, image 2 de 2
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: étape 3, image 1 de 2 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: étape 4, image 1 de 2 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: étape 4, image 2 de 2
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: étape 5, image 1 de 2 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: étape 5, image 2 de 2
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
cade knott
Membre depuis le 10/02/18
481 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 770
