Aller au contenu principal
DJI Phantom 4 Advanced Remote Controller Battery Replacement
Ce dont vous avez besoin
  1. DJI Phantom 4 Advanced Remote Controller Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Battery Replacement: étape 2, image 1 de 2 DJI Phantom 4 Advanced Remote Controller Battery Replacement: étape 2, image 2 de 2
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Battery Replacement: étape 3, image 1 de 2 DJI Phantom 4 Advanced Remote Controller Battery Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Battery Replacement: étape 4, image 1 de 2 DJI Phantom 4 Advanced Remote Controller Battery Replacement: étape 4, image 2 de 2
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Battery Replacement: étape 5, image 1 de 2 DJI Phantom 4 Advanced Remote Controller Battery Replacement: étape 5, image 2 de 2
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Battery Replacement, Battery: étape 6, image 1 de 1
    • The battery is attached to the back plastic, and is towards the bottom of the remote.
    • Unplug the cord that is connected to the bottom of the main board.
  7. DJI Phantom 4 Advanced Remote Controller Battery Replacement: étape 7, image 1 de 1
    • After the cord is unplugged, remove the battery by lifting upon the plastic cover, which the battery is attached to.
  8. DJI Phantom 4 Advanced Remote Controller Battery Replacement: étape 8, image 1 de 1
    • Once the cover is off you can access the battery.
8 autres ont terminé cette réparation.
cade knott
Membre depuis le 10/02/18
481 Réputation
3 tutoriels rédigés
Équipe
4 commentaires
Grrrrrreat Job!
Rick Artman - Réponse
Wo kann ich den Akku bestellen? Danke für die Hilfe!
Xl S - Réponse
does someone know where to buy the akku?
Xl S - Réponse
Ich habe ein Erzatz Akku eingesetzt mit den gleichen Strom Werten, beim aufladen stelle ich fest das der Akku nicht ladet..
Es blinkt bloß ( schnell) auf einer LED.
Wo kann die Ursache liegen.
Matthias Meier - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 37
30 derniers jours : 189
Total : 12,566
