Aller au contenu principal
DJI Spark Camera Replacement
Ce dont vous avez besoin
  1. DJI Spark Camera Replacement, Propellers: étape 1, image 1 de 1
    • Push down on the propeller that is being replaced.
  2. DJI Spark Camera Replacement: étape 2, image 1 de 2 DJI Spark Camera Replacement: étape 2, image 2 de 2
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Camera Replacement, Battery: étape 3, image 1 de 3 DJI Spark Camera Replacement, Battery: étape 3, image 2 de 3 DJI Spark Camera Replacement, Battery: étape 3, image 3 de 3
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Camera Replacement, Lid: étape 4, image 1 de 3 DJI Spark Camera Replacement, Lid: étape 4, image 2 de 3 DJI Spark Camera Replacement, Lid: étape 4, image 3 de 3
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
  5. DJI Spark Camera Replacement: étape 5, image 1 de 3 DJI Spark Camera Replacement: étape 5, image 2 de 3 DJI Spark Camera Replacement: étape 5, image 3 de 3
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Camera Replacement, Camera: étape 6, image 1 de 2 DJI Spark Camera Replacement, Camera: étape 6, image 2 de 2
    • Disconnect two gold antenna next to the internal GPS while removing the motherboard.
  7. DJI Spark Camera Replacement: étape 7, image 1 de 3 DJI Spark Camera Replacement: étape 7, image 2 de 3 DJI Spark Camera Replacement: étape 7, image 3 de 3
    • Remove all the Phillips #0 screws attaching the motherboard to the drone.
    • It is the piece with both the fan and GPS module on it.
  8. DJI Spark Camera Replacement: étape 8, image 1 de 2 DJI Spark Camera Replacement: étape 8, image 2 de 2
    • Remove the 3.0 mm Phillips #000 screw.
  9. DJI Spark Camera Replacement: étape 9, image 1 de 3 DJI Spark Camera Replacement: étape 9, image 2 de 3 DJI Spark Camera Replacement: étape 9, image 3 de 3
    • Remove the two Phillips #0 screws on the right and left sides.
    • Once removed, pull the front facing sensor out.
  10. DJI Spark Camera Replacement: étape 10, image 1 de 3 DJI Spark Camera Replacement: étape 10, image 2 de 3 DJI Spark Camera Replacement: étape 10, image 3 de 3
    • Gently remove the gimbal along with the camera from the top of the device.
Amelia Hagberg
Membre depuis le 10/21/19
415 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G7, Botvin Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G7, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G7
3 membres
7 tutoriels rédigés
2 commentaires
Good start, but missing many steps and details.
Basil Yokarinis - Réponse
I am now going to try and fix my drone. thank you so much
sebasnavarro1116 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 28
Total : 5,763
