Aller au contenu principal
DJI Spark Cooling Fan Replacement
Ce dont vous avez besoin
  1. DJI Spark Cooling Fan Replacement, Propellers: étape 1, image 1 de 1
    • Push down on the propeller that is being replaced.
  2. DJI Spark Cooling Fan Replacement: étape 2, image 1 de 2 DJI Spark Cooling Fan Replacement: étape 2, image 2 de 2
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Cooling Fan Replacement, Battery: étape 3, image 1 de 3 DJI Spark Cooling Fan Replacement, Battery: étape 3, image 2 de 3 DJI Spark Cooling Fan Replacement, Battery: étape 3, image 3 de 3
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Cooling Fan Replacement, Lid: étape 4, image 1 de 3 DJI Spark Cooling Fan Replacement, Lid: étape 4, image 2 de 3 DJI Spark Cooling Fan Replacement, Lid: étape 4, image 3 de 3
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
  5. DJI Spark Cooling Fan Replacement: étape 5, image 1 de 3 DJI Spark Cooling Fan Replacement: étape 5, image 2 de 3 DJI Spark Cooling Fan Replacement: étape 5, image 3 de 3
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Cooling Fan Replacement, Cooling Fan: étape 6, image 1 de 3 DJI Spark Cooling Fan Replacement, Cooling Fan: étape 6, image 2 de 3 DJI Spark Cooling Fan Replacement, Cooling Fan: étape 6, image 3 de 3
    • Remove the fan.
    • It is attached to the motherboard with several pieces of adhesive.
  7. DJI Spark Cooling Fan Replacement: étape 7, image 1 de 2 DJI Spark Cooling Fan Replacement: étape 7, image 2 de 2
    • Trace the fan wires to the side of the panel.
    • Unplug the wire from its connector.
Uzochi Anyanwu
Membre depuis le 10/21/19
408 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G7, Botvin Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G7, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G7
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 1,403
