Aller au contenu principal
DJI Spark Internal GPS Replacement
Ce dont vous avez besoin
  1. DJI Spark Internal GPS Replacement, Propellers: étape 1, image 1 de 1
    • Push down on the propeller that is being replaced.
  2. DJI Spark Internal GPS Replacement: étape 2, image 1 de 2 DJI Spark Internal GPS Replacement: étape 2, image 2 de 2
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Internal GPS Replacement, Battery: étape 3, image 1 de 3 DJI Spark Internal GPS Replacement, Battery: étape 3, image 2 de 3 DJI Spark Internal GPS Replacement, Battery: étape 3, image 3 de 3
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Internal GPS Replacement, Lid: étape 4, image 1 de 3 DJI Spark Internal GPS Replacement, Lid: étape 4, image 2 de 3 DJI Spark Internal GPS Replacement, Lid: étape 4, image 3 de 3
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
  5. DJI Spark Internal GPS Replacement: étape 5, image 1 de 3 DJI Spark Internal GPS Replacement: étape 5, image 2 de 3 DJI Spark Internal GPS Replacement: étape 5, image 3 de 3
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Internal GPS Replacement, GPS: étape 6, image 1 de 2 DJI Spark Internal GPS Replacement, GPS: étape 6, image 2 de 2
    • Identify the GPS module on the motherboard.
    • The GPS module will be labeled as ‘DJI G116’.
  7. DJI Spark Internal GPS Replacement: étape 7, image 1 de 2 DJI Spark Internal GPS Replacement: étape 7, image 2 de 2
    • Remove the four 6.0 mm Phillips #000 screws holding the GPS module to the motherboard.
  8. DJI Spark Internal GPS Replacement: étape 8, image 1 de 2 DJI Spark Internal GPS Replacement: étape 8, image 2 de 2
    • Pick up the GPS module.
    • Carefully disconnect the GPS module ribbon cable from the motherboard.
    • Remove the GPS module.
Amelia Hagberg
Membre depuis le 10/21/19
415 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G7, Botvin Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G7, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G7
3 membres
7 tutoriels rédigés
3 commentaires
How About Spark's Wifi can't find?
Mark Ryan Fontelar - Réponse
GPS module ribbon cable is broken where can i buy?
manzoorsp67 - Réponse
please if some one have it send it to me
i will pay u
manzoorsp67 -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 39
Total : 1,962
