Introduction
Be sure to order the proper buttons. To ensure a proper match, you can order from the manufacturer. Other than that, this replacement will be quick and easy.
You will have to remove the back of the tablet. To do this take the plastic opening tool, and insert it into the side of the tablet and twist.This will pop off the side.
  • You will have to remove the back of the tablet. To do this take the plastic opening tool, and insert it into the side of the tablet and twist.This will pop off the side.
  • Slowly pull up on the cover until it is completely off.
Ajouter un commentaire
Buttons will be located on the white back case. Apply small amount of pressure, and they should pop out.
  • Buttons will be located on the white back case. Apply small amount of pressure, and they should pop out.
Kaitlyn Hayes
Membre depuis le 21/01/2015
408 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 5-2, Brown Winter 2015 Membre de l'équipe USF Tampa, Team 5-2, Brown Winter 2015
USFT-BROWN-W15S5G2
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 7
Total : 409
