Aller au contenu principal
DOSS SoundBox Base-plate Removal Replacement
Ce dont vous avez besoin
  1. DOSS SoundBox Base-plate Removal Replacement, Base-plate Removal: étape 1, image 1 de 3 DOSS SoundBox Base-plate Removal Replacement, Base-plate Removal: étape 1, image 2 de 3 DOSS SoundBox Base-plate Removal Replacement, Base-plate Removal: étape 1, image 3 de 3
    • Locate the four 3/32" screws on the bottom of your device.
    • Using a JIS #00 screwdriver, remove the four 3/32" screws.
    • After removing the screws, lift the cover off of the device.
  2. DOSS SoundBox Base-plate Removal Replacement: étape 2, image 1 de 1
    • Using a JIS #1 screwdriver, remove the six 3/32" screws that attach the base-plate to the speaker enclosure. These screws are marked with red circles.
    • Using a JIS #000 screwdriver, remove the two 1/16" screws from the areas marked with an orange circle.
    • Having the magnetic pad handy will be beneficial, as these screws are very small and easily lost.
  3. DOSS SoundBox Base-plate Removal Replacement: étape 3, image 1 de 1
    • Lift the base-plate off of the enclosure.
2 autres ont terminé cette réparation.
Brendan Harkreader
Membre depuis le 09/27/18
517 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 33
Total : 1,972
