Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
  1. Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body. Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
    • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
    • Using a Magnetic Mat throughout this process will help prevent losing screws.
  2. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  3. Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires. Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
    • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
  4. Use a soldering iron to de-solder the two speaker wires from the speaker itself. The speakers are ready to be removed and replaced.
    • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
    • The speakers are ready to be removed and replaced.
    • Ensure that the device is turned off when handling bare wire.
    • Soldering iron is very hot.
To reassemble your device, follow instructions in reverse order.
Brendan Harkreader
Membre depuis le 27/09/2018
434 Réputation
3 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 57
Total : 921
