Aller au contenu principal
Pour réparer ensemble - Je crée un compte
DWFP55130 Regulator spring Replacement
Ce dont vous avez besoin
  1. DWFP55130 Regulator spring Replacement, Remove regulator knob: étape 1, image 1 de 1
    • Unscrew and remove the black plastic regulator knob. While unscrewing, it will reach a stop and will keep like cannot unscrew further. Just break through the stop and unscrew to completely remove
    Demander à FixBot
    Ajouter un commentaire
  2. DWFP55130 Regulator spring Replacement, Remove plunger actuator: étape 2, image 1 de 1
    • Use needle nose pliers to remove the plunger.
    Demander à FixBot
  3. DWFP55130 Regulator spring Replacement, Use Philips #3 (large) screw driver: étape 3, image 1 de 1
    • Very gently unscrew the valve with a Philips #3 screwdriver. Take care not to destroy the plastic part
    Demander à FixBot
  4. DWFP55130 Regulator spring Replacement, Remove plastic valve: étape 4, image 1 de 1
    • Use needle nose pliers to pull plastic valve assembly out
    Demander à FixBot
  5. DWFP55130 Regulator spring Replacement, Replace broken screw: étape 5, image 1 de 1
    • Replace screw if broken. Photo is not of the original spring. The original spring had corroded and broken into 50 pieces. The spring doesn’t have to be a perfect fit, just has to hold the part in place. The original spring was approx 6mm wide, 20mm tall and 0.5mm thickness wire.
    Demander à FixBot
  6. DWFP55130 Regulator spring Replacement, Reassemble: étape 6, image 1 de 1
    • Carry out steps in reverse to reassemble compressor and you’re done
    Demander à FixBot
Imran Latif
Membre depuis le 02/08/23
158 Réputation
1 tutoriel rédigé
5 commentaires de tutoriel
do you know the replacement part numbers just in case?
myke - Réponse Partager
The replacement parts are not listed in the manual and not available for sale. Hence this workaround.
Imran Latif - Réponse Partager
what type of spring did you replace it with?
Gaeilge 6 - Réponse Partager
Random screw I found from a 3D printer part. Size and shape were both different than the original spring. As long as the dimension are similar to 6mm wide and 20mm tall, it would work. The spring I used was not 6mm by 2omm but close enough that it worked.
Replaced and still leaks. Tried replacing o ring and still leaks.
Rollin Blanton - Réponse Partager
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 16
30 derniers jours : 119
Total : 2,134
