Aller au contenu principal
DYMO LabelPOINT 100 Keypad Replacement
Ce dont vous avez besoin
  1. DYMO LabelPOINT 100 Keypad Replacement, Remove Screws To The Access Panel: étape 2, image 1 de 2 DYMO LabelPOINT 100 Keypad Replacement, Remove Screws To The Access Panel: étape 2, image 2 de 2
    • Use Phillips #00 Screwdriver to remove the three screws that hold the upper portion of the access panel.
    • Remove the blade cutter assembly.
    • Use Phillips #00 Screwdriver to remove the last two screws located in the battery panel that holds the bottom portion of the access panel.
  2. DYMO LabelPOINT 100 Keypad Replacement, Remove Access Panel: étape 3, image 1 de 1
    • Gently remove the access panel from the right side of the device.
    • Some electrical wiring will be exposed and will not detach. Be careful not to damage any electrical wiring when removing access panel.
  3. DYMO LabelPOINT 100 Keypad Replacement, Removing Circuit Board: étape 4, image 1 de 2 DYMO LabelPOINT 100 Keypad Replacement, Removing Circuit Board: étape 4, image 2 de 2
    • Use Phillips #00 Screwdriver to remove three screws that hold down the circuit board.
    • Gently lift the bottom of the circuit board, revealing the keypad.
    • Be careful not to damage any components on the circuit board when disassembling.
  4. DYMO LabelPOINT 100 Keypad Replacement, Remove Keypad: étape 5, image 1 de 1
    • Remove the keypad from the front facing cover
    • When installing the new keypad, make sure all buttons are correctly set in each hole so that each button can be pressed.
Mike Dam
Membre depuis le 09/25/14
201 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 5-2, Mcgee Fall 2014 Membre de l'équipe USF Tampa, Team 5-2, Mcgee Fall 2014
USFT-MCGEE-F14S5G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 20
Total : 1,093
