Aller au contenu principal
Daisy Model 10 Carbine Cocking Lever Replacement
Ce dont vous avez besoin
  1. Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: étape 1, image 1 de 3 Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: étape 1, image 2 de 3 Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: étape 1, image 3 de 3
    • Make sure the safety is on!
    • Place the carbine with the saddle ring and leather thong facing upwards.
    • Locate the screw head on the cocking lever.
    • There should be one on either side of the saddle ring and one on the cocking lever assembly.
    • Place a #2 Phillips Screwdriver in the 11/16ths of an inch, matte black screw on the cocking lever assembly. Twist with a counter-clockwise motion.
    • Completely remove the screws.
    • Be wary of the black washers on the other side of the Carbine. Be sure to keep track of them once they fall out after the screws are removed
  2. Daisy Model 10 Carbine Cocking Lever Replacement, Removing the Lever: étape 2, image 1 de 2 Daisy Model 10 Carbine Cocking Lever Replacement, Removing the Lever: étape 2, image 2 de 2
    • Remove the cocking lever by placing your dominant hand’s fingers through the cocking lever handle.
    • With your fingers in the handle, slide the lever towards the butt of the carbine.
    • Finally, pull the cocking lever and carbine in opposite directions to replace the cocking lever.
Timothy Gachot
Membre depuis le 10/12/14
237 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 6-20, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 6-20, Maness Fall 2014
CPSU-MANESS-F14S6G20
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 11
Total : 2,386
