Aller au contenu principal
Dangle Earrings Jump Ring Replacement
Ce dont vous avez besoin
  1. Dangle Earrings Jump Ring Replacement, Jump Ring: étape 1, image 1 de 1
    • Locate where the earring stud/hook has detached.
    • Look at the two pieces of the dangle earrings for a small loop or jump ring on both pieces.
  2. Dangle Earrings Jump Ring Replacement: étape 2, image 1 de 1
    • Using a chain nose plier, carefully grip the jump ring by its side.
    • Use a cutting plier to cut a small opening in the loop.
  3. Dangle Earrings Jump Ring Replacement: étape 3, image 1 de 1
    • With both pliers use the cutting plier to gently grip the side of the small jump ring.
    • Using the small nose chain pliers pull back on the small jump ring to create an opening.
  4. Dangle Earrings Jump Ring Replacement: étape 4, image 1 de 1
    • With the small chain nose pliers grip the jump ring.
    • Insert the stud/hook portion of the earring into the jump ring.
  5. Dangle Earrings Jump Ring Replacement: étape 5, image 1 de 1
    • Use the jump ring to reattach the the stud.
    • Insert the main portion of the earring into the jump ring with the stud/hoop.
  6. Dangle Earrings Jump Ring Replacement: étape 6, image 1 de 1
    • Use both pliers to close the loop.
    • Firmly grip the edge of the loop using a pair of cutting pliers.
    • With a pair of small chain grip pliers gently push the end of the jump ring forward to close the loop.
  7. Dangle Earrings Jump Ring Replacement: étape 7, image 1 de 1
    • Gently tug on either side of the earring to ensure the loop is closed securely.
    • If this test fails, refer back to step 6.
Angelika Dela Torre
Membre depuis le 01/16/22
145 Réputation
1 tutoriel rédigé
Équipe
York University, Team R-7, Melo-Thaiss Winter 2022 Membre de l'équipe York University, Team R-7, Melo-Thaiss Winter 2022
YORK-MELO-THAISS-W22SRG7
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 30
Total : 329
