Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dash DSY007SS Yogurt Maker Disassembly
Ce dont vous avez besoin
  1. Dash DSY007SS Yogurt Maker Disassembly, Dash DSY007SS Yogurt Maker: étape 1, image 1 de 3 Dash DSY007SS Yogurt Maker Disassembly, Dash DSY007SS Yogurt Maker: étape 1, image 2 de 3 Dash DSY007SS Yogurt Maker Disassembly, Dash DSY007SS Yogurt Maker: étape 1, image 3 de 3
    • Remove the lid of the yogurt maker.
    • Flip the yogurt maker over so the bottom is facing upward.
    • Remove four 3.5mm screws from the bottom using a Phillips #00 screwdriver.
    Demander à FixBot
    Ajouter un commentaire
  2. Dash DSY007SS Yogurt Maker Disassembly: étape 2, image 1 de 3 Dash DSY007SS Yogurt Maker Disassembly: étape 2, image 2 de 3 Dash DSY007SS Yogurt Maker Disassembly: étape 2, image 3 de 3
    • Separate the two halves of the yogurt maker.
    • The power cord and the heating wire are still connected. This means that the yogurt maker will not be completely separate. However, the two pieces can be laid down to expose the internal wiring.
    • Remove four screws holding the power cable in place using a Phillips #00 screwdriver.
    • Remove the plastic that is holding the cord down.
    Demander à FixBot
  3. Dash DSY007SS Yogurt Maker Disassembly: étape 3, image 1 de 3 Dash DSY007SS Yogurt Maker Disassembly: étape 3, image 2 de 3 Dash DSY007SS Yogurt Maker Disassembly: étape 3, image 3 de 3
    • Gently pull up on the circuit board and wiggle it side to side to release it from the two retaining tabs.
    • You now have access to the main circuit board that allows transfer between the power supply and heat of the appliance.
    Demander à FixBot
Ligne d'arrivée
Ava Wong
Membre depuis le 09/10/25
147 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 20
Total : 119
