Aller au contenu principal
Dashcam DOD LS300W Battery Replacement
Ce dont vous avez besoin
  1. Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: étape 1, image 1 de 3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: étape 1, image 2 de 3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: étape 1, image 3 de 3
    • Using an opening tool, pry open the seam on the bottom of the dash cam to separate the two parts of the device.
  2. Dashcam DOD LS300W Battery Replacement: étape 2, image 1 de 2 Dashcam DOD LS300W Battery Replacement: étape 2, image 2 de 2
    • Notice the connection of + and - on the top left side of the inside of the dash cam. Make note of this as it will be important to remember when you solder on the new battery.
    • Desolder the old battery. This is a 250mAh.
  3. Dashcam DOD LS300W Battery Replacement: étape 3, image 1 de 3 Dashcam DOD LS300W Battery Replacement: étape 3, image 2 de 3 Dashcam DOD LS300W Battery Replacement: étape 3, image 3 de 3
    • The new battery is 400mAh. and fits just in the battery location.
    • Solder in the new battery.
    • Then place the new battery into the space previously occupied by the old battery.
    • See the difference between old and new battery.
    • Be careful to solder the positive side of the new battery into the same spot that the old battery was soldered into.
  4. Dashcam DOD LS300W Battery Replacement: étape 4, image 1 de 1
    • Put the dashcam back together.
    • Charge the battery to the full level, and you are ready to go.
Once again, thank you for checking out this guide and I hope it helped!
2 autres ont terminé cette réparation.
Pierre
Membre depuis le 04/02/13
542 Réputation
3 tutoriels rédigés
2 commentaires
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
Russell Edwards - Réponse
Hi Russell, I found this battery on Ebay.
Good luck.
Cheers.
Pierre - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 30
Total : 6,354
