Aller au contenu principal
Datawind Ubislate 7ci Battery Replacement
Ce dont vous avez besoin
  1. Datawind Ubislate 7ci Battery Replacement, Battery: étape 1, image 1 de 2 Datawind Ubislate 7ci Battery Replacement, Battery: étape 1, image 2 de 2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • Be careful of the device's small wiring when separating the two halves.
  2. Datawind Ubislate 7ci Battery Replacement: étape 2, image 1 de 3 Datawind Ubislate 7ci Battery Replacement: étape 2, image 2 de 3 Datawind Ubislate 7ci Battery Replacement: étape 2, image 3 de 3
    • Remove the black tape.
    • Be careful not to remove the tablet camera.
  3. Datawind Ubislate 7ci Battery Replacement: étape 3, image 1 de 3 Datawind Ubislate 7ci Battery Replacement: étape 3, image 2 de 3 Datawind Ubislate 7ci Battery Replacement: étape 3, image 3 de 3
    • Use a soldering iron to remove the battery from both its attachment points.
    • Pry off the battery using an opening tool.
  4. Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: étape 4, image 1 de 2 Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: étape 4, image 2 de 2
    • Insert your replacement battery in the same spot as the old battery.
    • Tape battery into place.
  5. Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: étape 5, image 1 de 2 Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: étape 5, image 2 de 2
    • Solder the new battery to the connection points.
    • Press the back cover on firmly until it clicks.
6 autres ont terminé cette réparation.
Mekides
Membre depuis le 10/20/14
40 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G3
3 membres
6 tutoriels rédigés
2 commentaires
On my 7Ci the battery is SFH-HLKJ-204.
Datawind doesn't sale those pieces.
Where can I find one?
What type is it, voltage and so?
THX!
ylco - Réponse
3.7V, 2200mAh lithium ion. Yiu can get a bigger or smaller one depending on shat you want.
Jessica Parnelli Fawkes - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 9,075
