Introduction
Designed as a low cost tablet for students in India, Datawind's Ubislate 7CI sells for about $35, to students in India, with the price subsidized by the government. The device is 7.2 by 4.8 by .4 inches (HWD) and weighs 11.2 ounces.
Pièces
Aucune pièce nécessaire.
Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
Ajouter un commentaire
Run your prying tool along the front edge of the device to pop off the front cover.
  • Run your prying tool along the front edge of the device to pop off the front cover.
  • Once the halves are separated your device should look like this.
  • (HINT: be careful of the device's small wiring when separating the two halves.)
  • Remove the black tape that is circled.
  • The camera is circled in this picture.
  • Carefully remove the camera from its housing.
  • Slide the new camera into its housing carefully.
  • it should look like the second picture when you are finished
  • Press the back cover of the tablet on firmly until it clicks
2 autre(s) ont terminé cette réparation.
Mekides
Membre depuis le 20/10/2014
40 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G3
3 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 155
