Aller au contenu principal
De' Longhi CTOV 2103- AZ
Ce dont vous avez besoin
  1. De' Longhi CTOV 2103- AZ, Pull the lever: étape 1, image 1 de 3 De' Longhi CTOV 2103- AZ, Pull the lever: étape 1, image 2 de 3 De' Longhi CTOV 2103- AZ, Pull the lever: étape 1, image 3 de 3
    • First unplug the cable. ...Pull off the lever, it is snapped in.
    • Pull out the drawer.
    • Now clean it with a vacuum.
    • On the underside are 4 screws Torx 10 resistant visible - in each corner one.
  2. De' Longhi CTOV 2103- AZ, Screw: étape 2, image 1 de 2 De' Longhi CTOV 2103- AZ, Screw: étape 2, image 2 de 2
    • Detail of the screw
  3. De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: étape 3, image 1 de 3 De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: étape 3, image 2 de 3 De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: étape 3, image 3 de 3
    • here you have two pictures of the housing and the chrome plastic frame.
  4. De' Longhi CTOV 2103- AZ, Lever: étape 4, image 1 de 2 De' Longhi CTOV 2103- AZ, Lever: étape 4, image 2 de 2
    • Here you have details of the lever and how it is snapped in the mechanic.
    • This shows you how to unlock it when you dismantle the housing. Good luck. ;)
  5. De' Longhi CTOV 2103- AZ, Tempeaturesensor: étape 5, image 1 de 2 De' Longhi CTOV 2103- AZ, Tempeaturesensor: étape 5, image 2 de 2
    • Detail of the Sensor: It is the little black pearl at the black hoses which is strapped to the white hose.
  6. De' Longhi CTOV 2103- AZ: étape 6, image 1 de 3 De' Longhi CTOV 2103- AZ: étape 6, image 2 de 3 De' Longhi CTOV 2103- AZ: étape 6, image 3 de 3
    • The connector from the main platine to the switch platine.
  7. De' Longhi CTOV 2103- AZ: étape 7, image 1 de 3 De' Longhi CTOV 2103- AZ: étape 7, image 2 de 3 De' Longhi CTOV 2103- AZ: étape 7, image 3 de 3
    • Details of the plug and the bottom part after disassembly.
    • Where to find the plug for the yellow ground wire i show you in the next step. :)
  8. De' Longhi CTOV 2103- AZ: étape 8, image 1 de 2 De' Longhi CTOV 2103- AZ: étape 8, image 2 de 2
    • here you can see where the yellow cable belongs to.
  9. De' Longhi CTOV 2103- AZ, Reassembly: étape 9, image 1 de 3 De' Longhi CTOV 2103- AZ, Reassembly: étape 9, image 2 de 3 De' Longhi CTOV 2103- AZ, Reassembly: étape 9, image 3 de 3
    • Reassembly: Putt all cables at the right places, don't forget the yellow cable at the housing !!!
    • Look at the picture how to fit in the metal notch in the right place !
  10. De' Longhi CTOV 2103- AZ: étape 10, image 1 de 3 De' Longhi CTOV 2103- AZ: étape 10, image 2 de 3 De' Longhi CTOV 2103- AZ: étape 10, image 3 de 3
    • Here the notch is in the right place.
    • Do NOT forget to make an insulation test. Check the wiring with a multimeter.
    • Made in China.
    • Hope it was fun and may the pictures help you. Greets. :)
2 autres ont terminé cette réparation.
Schwarzstein
Membre depuis le 07/15/13
2 847 Réputation
13 tutoriels rédigés
2 commentaires
The lever broke on my toaster. And it's difficult to glue it.
skan - Réponse
My daughter toasted a piece of bread but the bread burned and caught fire. I've opened the toaster, and see no fire-damage. Although, it is impossible to toast because the lever won't stay down.
Dieter Troubleyn - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 15
30 derniers jours : 59
Total : 2,572
