Introduction
Be careful when disassembling the tubes and connections. They may be tightly attached to the machine and may take some effort to remove.
Ce dont vous avez besoin
Flip open the top panel to reveal water reservoir.
Grab the water reservoir by the handle and lift out.
Flip the device on its head.
Using the Phillips #2 screwdriver, unscrew the four 12 mm screws found at each corner of the bottom panel.
Lift the panel off or flip the device over and let the panel drop out.
Flip the device on its head, front end facing you.
Using the Phillips #2 unscrew the two 52 mm screws found underneath the top portion of the device.
Flip the device and remove one end of the tube from the water reservoir hole.
Remove both sets of wires from the black box of the water pump.
Cut off the zip-tie holding all the wires together.
Isolate the blue wires from the rest and remove from core as necessary.
4 autres ont terminé cette réparation.
