Aller au contenu principal
Pièces
Aucune pièce spécifiée.
  1. Flip open the top panel to reveal water reservoir. Grab the water reservoir by the handle and lift out.
    • Flip open the top panel to reveal water reservoir.
    • Grab the water reservoir by the handle and lift out.
  2. Before flipping the device, removed the black container and grill.
    • Before flipping the device, removed the black container and grill.
    • Flip the device on its head, front end facing you.
    • Using the Phillips #2 unscrew the two 52 mm screws found underneath the top portion of the device.
  3. Flip the device back to its proper orientation.
    • Flip the device back to its proper orientation.
    • Using the Phillips #2 screwdriver remove the two 52 mm screws found on the lip next to the reservoir.
  4. Insert the two plastic opening tools beneath the top knob. Use the two plastic opening tools as leverage to lift the top knob off.
    • Insert the two plastic opening tools beneath the top knob.
    • Use the two plastic opening tools as leverage to lift the top knob off.
  5. Grasp the lid firmly with both hands.
    • Grasp the lid firmly with both hands.
    • Pull mightily with both hands away from the device.
    • If you hear a slight snapping sound, it is supposed to do that.
  6. Use a plastic opening tool to push in the slot on the back panel while lifting. Similarly, reach into where the reservoir used to be and insert a plastic spudger underneath the  inside panel.
    • Use a plastic opening tool to push in the slot on the back panel while lifting.
    • Similarly, reach into where the reservoir used to be and insert a plastic spudger underneath the inside panel.
    • We recommend to not use your fingers for this step because there is a chance they will be pinched.
  7. You are now ready to lift the top off. Place one hand near the back, the other at the front, and lift.
    • You are now ready to lift the top off.
    • Place one hand near the back, the other at the front, and lift.
    • You may want to lift the front and back individually by pulling one a little off the part before the other. Afterwards, lifting the top off entirely will be easier.
David Griffith
Membre depuis le 01/10/2015
1 441 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 4-2, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 4-2, Maness Fall 2015
CPSU-MANESS-F15S4G2
4 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 53
