Outils
Pièces
Aucune pièce spécifiée.
Remove the drip tray, the water tank and the pulp container.
The left side is a bit stuck. Place a plastic opening tool in the gap between the front and left side panel above the opening for the water tank. Lift the gap slightly larger.
Then place the tool in the gap between the front and left side panel under the opening for the water tank. Increase the gap and push the side part about 2 cm to the rear.
Lift out the left side piece.
Repeat the steps in order to reassemble your device.
4 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
100%
irlanda nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
