Aller au contenu principal
DeWalt D26451 Power Switch Replacement
Ce dont vous avez besoin
  1. DeWalt D26451 Power Switch Replacement, Power Cord: étape 1, image 1 de 1
    • Please wear safety glasses while completing this guide.
    • Remove screws (3) from cap by using the T20 torx attachment and unscrewing in a leftward motion.
  2. DeWalt D26451 Power Switch Replacement: étape 2, image 1 de 1
    • Gently pry the cap off using your fingers or spudger tool.
  3. DeWalt D26451 Power Switch Replacement: étape 3, image 1 de 1
    • Once cap is off, expose and locate the power cord mounting bracket and remove the 2 screws holding the wire down by using the T15 torx attachment. Once the cord is loose, pull the connectors out
  4. DeWalt D26451 Power Switch Replacement: étape 4, image 1 de 1
    • Loosen the white and black wire terminals
  5. DeWalt D26451 Power Switch Replacement: étape 5, image 1 de 1
    • Insert new power cord terminals and tighten down
    • Do not over-tighten
  6. DeWalt D26451 Power Switch Replacement, Power Switch: étape 6, image 1 de 1
    • Remove screws (3) from the cap using a T20 torx attachment by unscrewing in a leftward motion
  7. DeWalt D26451 Power Switch Replacement: étape 7, image 1 de 1
  8. DeWalt D26451 Power Switch Replacement: étape 8, image 1 de 1
    • Once the cap is removed, the switch and connectors should be exposed
  9. DeWalt D26451 Power Switch Replacement: étape 9, image 1 de 1
    • Remove both connectors from the switch
Shelby LeQuire
Membre depuis le 01/29/16
639 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 20
Total : 1,287
