Aller au contenu principal
DeWalt D28110 Power Switch Replacement
Ce dont vous avez besoin
  1. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Gear Case: étape 1, image 1 de 1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws on the gear case.
    • Unplug the grinder before any disassembly.
  2. DeWalt D28110 Power Switch Replacement: étape 2, image 1 de 2 DeWalt D28110 Power Switch Replacement: étape 2, image 2 de 2
    • Pull out the gear case.
  3. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: étape 3, image 1 de 1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
  4. DeWalt D28110 Power Switch Replacement: étape 4, image 1 de 1
    • Use the edge of the spudger to loosen and remove the back panel.
  5. DeWalt D28110 Power Switch Replacement: étape 5, image 1 de 1
    • Remove the single 20-mm torx screw holding the rear panel in place.
  6. DeWalt D28110 Power Switch Replacement: étape 6, image 1 de 1
    • Pull back the rear side of the back panel.
  7. DeWalt D28110 Power Switch Replacement, Power Switch: étape 7, image 1 de 3 DeWalt D28110 Power Switch Replacement, Power Switch: étape 7, image 2 de 3 DeWalt D28110 Power Switch Replacement, Power Switch: étape 7, image 3 de 3
    • There is an inner plastic guard behind the motor shaft.
    • Unscrew the four screws at each corner.
    • The guard should pull out with a good firm tug.
  8. DeWalt D28110 Power Switch Replacement: étape 8, image 1 de 3 DeWalt D28110 Power Switch Replacement: étape 8, image 2 de 3 DeWalt D28110 Power Switch Replacement: étape 8, image 3 de 3
    • Just behind the inner guard is the button slide.
    • Use needle nose pliers to pinch and push the button's flanges together, and out of the slot.
  9. DeWalt D28110 Power Switch Replacement: étape 9, image 1 de 3 DeWalt D28110 Power Switch Replacement: étape 9, image 2 de 3 DeWalt D28110 Power Switch Replacement: étape 9, image 3 de 3
    • Using the J-1 screwdriver, unscrew the power cord wires from the red switch box (located in the back of the grinder).
  10. DeWalt D28110 Power Switch Replacement: étape 10, image 1 de 2 DeWalt D28110 Power Switch Replacement: étape 10, image 2 de 2
    • Disconnect the motor wires from the other side of the switch box.
    • They wires are connected as a sleeve to the flat pin out of the switch box. A firm pull should do it.
3 autres ont terminé cette réparation.
Kean Wee
Membre depuis le 01/22/15
495 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 18-6, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 18-6, Maness Winter 2015
CPSU-MANESS-W15S18G6
5 membres
7 tutoriels rédigés
Un commentaire
Very clear and concise guide with relevent pictures. Very well done, thank you
Michael Creel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 38
Total : 5,358
