Aller au contenu principal
DeWalt DCS380 Blade Shaft Replacement
Ce dont vous avez besoin
  1. DeWalt DCS380 Blade Shaft Replacement, Removing shoe and boot.: étape 1, image 1 de 1
    • Remove the battery before disassembly.
    • Remove the shoe by pressing the yellow button on the left side of the hand grip.
  2. DeWalt DCS380 Blade Shaft Replacement: étape 2, image 1 de 2 DeWalt DCS380 Blade Shaft Replacement: étape 2, image 2 de 2
    • Remove the two M8x18mm T20 bolts from the front plate.
  3. DeWalt DCS380 Blade Shaft Replacement: étape 3, image 1 de 1
    • Pull the front of the grip while holding the saw body in place.
  4. DeWalt DCS380 Blade Shaft Replacement, Blade Shaft: étape 4, image 1 de 2 DeWalt DCS380 Blade Shaft Replacement, Blade Shaft: étape 4, image 2 de 2
    • Remove the four M8x18mm T20 screws on the top of the gearbox.
    • Pull the top of the gearbox off and set the saw body aside.
  5. DeWalt DCS380 Blade Shaft Replacement: étape 5, image 1 de 2 DeWalt DCS380 Blade Shaft Replacement: étape 5, image 2 de 2
    • Remove the black plastic dust covers using the plastic pry bar.
    • Remove the two M5 lock nuts using a 5/16" socket.
  6. DeWalt DCS380 Blade Shaft Replacement: étape 6, image 1 de 2 DeWalt DCS380 Blade Shaft Replacement: étape 6, image 2 de 2
    • Turn the housing over and remove the two countersunk M5x17mm T20 bolts from the shaft yoke.
    • Remove the yoke.
  7. DeWalt DCS380 Blade Shaft Replacement: étape 7, image 1 de 2 DeWalt DCS380 Blade Shaft Replacement: étape 7, image 2 de 2
    • Pull the shaft out of the front of the housing.
    • Leave the shaft saddle in place over the holes in the cover.
    • Re-grease before re-assembly. If there are metal shavings or pieces of the broken shaft left in the gearbox make sure to remove them before re-greasing.
Jonathan Hicks
Membre depuis le 01/17/19
725 Réputation
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 29
Total : 862
