Aller au contenu principal
DeWalt DCS380 Trigger assembly Replacement
Ce dont vous avez besoin
  1. DeWalt DCS380 Trigger assembly Replacement, DeWalt DCS380 Grip Disassembly: étape 1, image 1 de 2 DeWalt DCS380 Trigger assembly Replacement, DeWalt DCS380 Grip Disassembly: étape 1, image 2 de 2
    • Remove the battery before dissasembly.
    • Remove the M3x16mm T10 screw from the back of the grip. Keep it separate from the rest of the grip screws
    • Remove the six M3.63x19 T15 screws from the grip.
  2. DeWalt DCS380 Trigger assembly Replacement: étape 2, image 1 de 3 DeWalt DCS380 Trigger assembly Replacement: étape 2, image 2 de 3 DeWalt DCS380 Trigger assembly Replacement: étape 2, image 3 de 3
    • Remove the top half of the grip.
    • Turn the saw over and locate the power connectors to the motor.
    • Use needle nose pliers to remove the spade connectors. Take care not to grab the wires on removal, only the end of the spade terminal.
    • Note the polarity for the power connectors and be sure they are not reversed on reassembly.
  3. DeWalt DCS380 Trigger assembly Replacement, Trigger assembly: étape 3, image 1 de 3 DeWalt DCS380 Trigger assembly Replacement, Trigger assembly: étape 3, image 2 de 3 DeWalt DCS380 Trigger assembly Replacement, Trigger assembly: étape 3, image 3 de 3
    • Take note of the position of the battery tension spring and safety switch before removal.
    • Lift the trigger assembly out of the grip.
Jonathan Hicks
Membre depuis le 01/17/19
725 Réputation
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 29
Total : 1,068
