Aller au contenu principal
DeWalt DW660 Motor Brushes Replacement
Ce dont vous avez besoin
  1. DeWalt DW660 Motor Brushes Replacement, Motor Brushes: étape 1, image 1 de 2 DeWalt DW660 Motor Brushes Replacement, Motor Brushes: étape 1, image 2 de 2
    • Remove the four 19mm T20 Torx screws at the rear of the device.
  2. DeWalt DW660 Motor Brushes Replacement: étape 2, image 1 de 3 DeWalt DW660 Motor Brushes Replacement: étape 2, image 2 de 3 DeWalt DW660 Motor Brushes Replacement: étape 2, image 3 de 3
    • Remove the other part of the back casing.
    • Unplug the black and white power wires from the motor.
  3. DeWalt DW660 Motor Brushes Replacement: étape 3, image 1 de 2 DeWalt DW660 Motor Brushes Replacement: étape 3, image 2 de 2
    • Pinch the blue brush wire between two fingers.
    • Pull on the wire, removing them from the motor.
  4. DeWalt DW660 Motor Brushes Replacement: étape 4, image 1 de 2 DeWalt DW660 Motor Brushes Replacement: étape 4, image 2 de 2
    • Using the metal spudger, lift up the coil spring that holds the carbon brushes in place.
    • While the spring is lifted up, remove the carbon brush by simply sliding it out of the slot.
  5. DeWalt DW660 Motor Brushes Replacement: étape 5, image 1 de 2 DeWalt DW660 Motor Brushes Replacement: étape 5, image 2 de 2
    • Repeat steps 3 and 4 to remove the other carbon brush.
    • When installing the new carbon brushes, make sure each brushes' lead wire is plugged into opposite ends of the motor.
    • Refer to the photos for visual assistance.
Joseph Pacitto
Membre depuis le 03/23/16
239 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-7, Isaacson Spring 2016 Membre de l'équipe UMass Dartmouth, Team 2-7, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G7
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 23
Total : 1,412
