Aller au contenu principal
DeWalt DW920 Lock Switch Replacement
Ce dont vous avez besoin
  1. DeWalt DW920 Lock Switch Replacement, Disassembly: étape 1, image 1 de 1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Lock Switch Replacement: étape 2, image 1 de 1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Lock Switch Replacement: étape 3, image 1 de 1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Lock Switch Replacement, Lock Switch: étape 4, image 1 de 1
    • Locate the switch on the top of the drill right before the bending joint.
  5. DeWalt DW920 Lock Switch Replacement: étape 5, image 1 de 2 DeWalt DW920 Lock Switch Replacement: étape 5, image 2 de 2
    • Firmly grasp the switch with two fingers and lift it straight up. The spring should remain attached to the switch during this process.
    • It should lift right out. If it is caught on anything do not force it out.
Stephen Rada
Membre depuis le 03/11/16
433 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 8-2, Botvin Spring 2016 Membre de l'équipe UMass Dartmouth, Team 8-2, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G2
2 membres
6 tutoriels rédigés
Un commentaire
This guide was descriptive and easy to follow. Good job!
DankMemerino - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 271
